Saginaw steering
mm
04-23-2003 06:02:16
I own a saginaw steering unit on 1850D The problem I am having is leakage out of the unit. I pulled the pinion and i saw no pinoin quad ring. I want to no how this goes on the pinoin or does it go in the shaft caviety. Where does the quad ring go?
Myron KY
04-23-2003 06:26:45
 Re: saginaw steering in reply to mm, 04-23-2003 06:02:16
The Quad Ring goes in the bottom of the pinion bore (shaft cavity). Then the pinion goes in. Make sure to align the timing marks on the pinion and piston.
Myron KY
jmendenhall
07-05-2006 07:48:05
 Re: Re: saginaw steering in reply to Myron KY, 04-23-2003 06:26:45
I am looking for the spec's on the sag. shafts slines. I have a char-lynn box and want to put in but do not know the size I need.
