1755 hyd
TP
04-22-2003 18:55:40
1755D that sometimes steering and hyd lock up then after a while will both work again ,any ideas ? could it be a sticking valve in the pump? Thanks for any suggestions. TOM
Jim Meade
04-23-2003 19:59:55
 Re: 1755 hyd in reply to TP, 04-22-2003 18:55:40
Is it full of hydraulic oil and have you purged the air from the system? Fill it up and run the steering wheel lock to lock a couple of times and see if that helps.
