1950 fuel sender
Craig
04-21-2003 16:07:24
Anyone know what the OHM range is correct for the sending unit on the 1950? The last one I bought for my 1900 from my Oliver dealer was just a universal type, but I did not think to measure it.
Craig
Myron KY
04-22-2003 06:48:49
 Re: 1950 fuel sender in reply to Craig, 04-21-2003 16:07:24
The last one I got from AGCO, for my 1850, was a generic one also. I tested it before installing by connecting the sender wire and grounding the mounting flange. Then I moved the float arm and watched the gauge to see if it followed the float arm position. This way, if the resistance (Ohm reading) was wrong I could return the sender, as it had not been installed and soaked in diesel. I did check it with an Ohm meter but don't remember what the resistance was. Just that it was 0 Ohms with the float arm in the full tank position. Myron KY
P.S. I did find some 2 valve/4 valve info for you and replied below.
