Engine Racing
RET
04-18-1999 05:00:26
I started my 77 and the engine took off racing. Thtottle was as slow as it would go. Could it be that the govenor is broke? If so how do I fix and where do I get a replacment. Thanks in advance for any and all help.
Shadetree
04-18-1999 10:37:00
 Re: Engine Racing in reply to RET, 04-18-1999 05:00:26
RET It sounds like the govenor is bad and you will have to take the linkage off and the three bolts on the front timing cover that hold it in place off and pull the govenor housing off. You should be able to get a replacement govenor at any Agco White Dealership in your area. When you get one it will probably take some linkage adjustments, the dealership may be able to help you there. Good Luck Shadetree
RET
04-18-1999 12:27:52
 Re: Re: Engine Racing in reply to Shadetree, 04-18-1999 10:37:00
Thanks for the help shadetree. Its appreciated.
Paul Stanley
04-18-1999 15:43:06
 Re: Re: Re: Engine Racing in reply to RET, 04-18-1999 12:27:52
RET,
When you start working on your govenor, if you run into any trouble, I have the shop manual that covers that tractor. Email me if you have any questions..... ..
