Random 1650 clunk
Brian
04-20-2003 19:50:47
My industrial 1650 has just developed a random clunk that sounds like it is coming from the top front of the transmission. This tractor probably has alot of hours with the majority of time being spent in neutral while the backhoe was being used.This tractor is direct drive and the noise is not from the engine.The noise goes away with the clutch depressed. I can see a slight wobble in the shaft that runs into the tranny. The shaft is not bent.Is there an inspection panel that can be removed.Is there a bearing in there? Can any repairs be made with the transmission in the tractor?Should I be concerned?The tractor operates fine and I don't feel the clunk in the shifter.Thank's for any help.
