Oc-4 magneto
art robertson
04-19-2003 18:04:45
can a oc-4 crawler with magneto /6 volt system be converted to a 12 volt system.if so,how.
Dave W,
04-22-2003 18:08:57
 Re: oc-4 magneto in reply to art robertson, 04-19-2003 18:04:45
If you put twelve volts to the starter, it may turn over too fast for the mag impulse to work.
Duane Larson
04-19-2003 20:42:39
Art,
The magneto is independent of the battery voltage - it is not hooked to the battery. So, if you stay with the magneto ignition system, you have to change the battery, starter, generator, and light bulbs. The ammeter should function properly, although less current will be drawn than with a 6V system. If you convert to a distributor ignition system you will have to locate a distributor and 12V coil, or 6V coil if you use a ballast resistor and bypass starting system.
Classic Generator in Texas can help you convert your present starter and generator, so you can keep the same cases.
Hope this helps-
Larry from MD
04-20-2003 09:23:57
 Re: Re: oc-4 magneto in reply to Duane Larson, 04-19-2003 20:42:39
Change the generator use the same starter.
