OC-15
Jim Meade
04-19-2003 17:33:04
What are the specs on the OC-15? Is it a good dozer? About what is one in working condition worth?
Bob
04-21-2003 09:19:37
 Re: OC-15 in reply to Jim Meade, 04-19-2003 17:33:04
The OC 15 was built in the late 50's and is a 100Hp tractor about D6 size in it's day. What is the serial number as there were changes along the way. Undercarriage is the most important as parts are not available for them. Only used parts. Some engine parts can be found but not cheap. It has a Hercules DRXC engine. I have the 30th machine built.
Jim Meade
04-21-2003 09:53:27
 Re: Re: OC-15 in reply to Bob, 04-21-2003 09:19:37
I don't know the SN, and have pretty much decided I don't want the tractor. The engine has been swapped out for a Perkins.
I'm looking for something like a D4 with a 6-way blade and power shift. I want to reshape waterways and grub out fencelines and then resell it. I doubt if the OC-15 with 2-way blade would be as handy as a smaller, livelier tractor for that purpose.
Deas Plant.
04-20-2003 00:18:06
Hi, Jim. You will be able to get specs on the OC 15 from the link below. Blake Malkamaki over there is the most helpful person I have found when it comes to Cletracs. If the specs aren't posted anywhere, e-mail Blake. You can also sign up there for free which enables you to post too.
I would imagine he would be able to give you a ball park figure for price too.
Hope this helps.
You have a wonderful day. Best wishes. Deas Plant.
