Oliver 88 serial number
Jeff
04-18-2003 20:20:03
I have an Oliver 88 serial number 125264 c88c. I know from looking it up tht it is a1949 but I don't have a clue what the c's on either side of the 88 mean. I am sure they are there for a reason as the 77 I have doesn't have anything like that on it. Seems I have read on here that those things sometimes told the gear ratio f the tractor or something like that. Is this what it is??
B A Star
04-18-2003 22:21:27
 Re: Oliver 88 serial number in reply to Jeff , 04-18-2003 20:20:03
You are correct, the c88c is the drive train code. It tells us which drive train the tractor had when shipped from the factory. Your tractor has a "special low" speed 1st and 3rd gears, other speeds are same as regular Row Crop.
John
04-19-2003 11:11:37
 Re: Re: Oliver 88 serial number in reply to B A Star, 04-18-2003 22:21:27
Do you have a complete list of serial number suffix's that you could post? I have a 77 that has a c77d at the end of it's serial number.
Jeff
04-19-2003 04:23:54
Thanks! That would explain why this thing has so much power in low gear. I use it to pull some right now but plan on restoring it and probably using it in a year or so as it still has everything including hydralics on it. Is there a book or website or something that lists these codes? I would like to know what they are on other models also so if I happen to run across one at a good deal I will know as much as possible about it.
