1950 hyd. control lever trouble
Craig
04-18-2003 06:40:49
The 1950 that I just bought is a little "junky", in need of some TLC for sure. But the engine,trans,hydra seem fine, runs great, good sheet metal AND it was cheep. Anyway the left (inside) hyd. control lever seems to be "disconnected", it does not spring to "center" and has no resistance at all???
Craig
Larry from MD
04-18-2003 08:10:51
 Re: 1950 hyd. control lever trouble in reply to Craig, 04-18-2003 06:40:49
The washer /key is likely broken off, that holds the inner yoke.Remove seat and top cover and the parts are visible.Try not to let any of the broken bits fall into the bottem.
