TRANS FLUID
KENNY YIKE
04-17-2003 13:14:44
I HAVE AN OLD OLIVER TRACTOR AND I NEED TO KNOW WHAT TYPE OF TRANS FLUID IT TAKES. MODEL-71CRR05
SN-0-1493
Don-WI
04-18-2003 15:38:30
 Re: TRANS FLUID in reply to KENNY YIKE, 04-17-2003 13:14:44
Does the sheet metal on the sides have the # on it? ex: 70, 77, 770, 1600, 1650, 1655? I'm not good at decifering ser. #'s & the like yet. If you are talking what the gears are in, a good 90 wt. oil is what you need. If in the hydra power/uver under, use dexron/mercon III (old type A fluid), or in the other part of trans, which is actually hydrualic fluid, just a good quality hydraulic oil will work. Hope this helps Donovan from Wisconsin
P.S. Typing in all caps is a pet peave of mine
