Cockshutt 550 shifting problem
Dale
04-16-2003 11:00:26
I have a Cockshutt 550 (1959 model year), and the problem is that the transmission input shaft continues to spin with the clutch disengaged, therefore causing difficult shifting. I've replaced the clutch pressure plate, and clutch disk, and linkage is adjusted properly, and with the engine off and clutch depressed the input shaft spins freely. The only thing I can imagine is that the pto shaft, which runs inside the transmission input shaft, somehow creates a drag on the transmission input shaft. Is that possible? Any ideas?
Mike (WA)
04-17-2003 08:00:02
 Re: Cockshutt 550 shifting problem in reply to Dale, 04-16-2003 11:00:26
I seem to be having the same problem with one of my tractors, but haven't torn into it yet. Find a parts manual and see if there are any bearings or bushings between the two shafts- also, I would assume that the rear of the transmission input shaft is carried in a bearing at the rear of the transmission case- if that bearing has failed, it might cause the input shaft to contact the PTO shaft, causing drag.
