keith
04-15-2003 19:34:13
hi all, i hope as usual you guys can help me me with this problem i have with my 1655,hydraulic pressure,it started last year with the remote cylinder,it would'nt go up or down when you pushed the lever ahead or back ,you had to keep playing with it too get it where you wanted the cylinder position to be ,and finally it got there with enough tries,so anyway this year i installed a front end loader,hooked up to the power beyond ports, as alot of youse said too do,and so did the dealer,anyway italso has a joystick on the loader valve,open centre that is also,so when i pull back the lever to raise the loader,it goes up about one half inch ,then super slow after that,the more you rev the tractor it goes a bit more faster,it goes down fine,so i put a pressure gauge in the drain port,up front near the filter on the left side sitting on the tractor,and i pulled the joystick back as if to raise the loader,and the pressure went to 1200 then 1300 then 1500 it;s really jumpy, the power steering works fine,one time the pressure actually went to 2000 and the loader raised just like it;s supposed to do,but that was it,so i took the hydraulic housing off and got the pump checked out at a reputable pump facility,they said the pump is fine,please...now after all that,what do you guys think could be the problem, if the pump is fine,,,what else could i check,any idea's would help,,, keith
