How do you engage the differential lock on an 1850?
Mike D.
04-15-2003 07:52:20
This is my first spring with this tractor. I'm spinning one tire and the other one is resting!
How do I lock the rearend so both tires will spin at the same time? My manual seems to be missing some critical pages.
Thanks in advance- Mike D.
John
04-20-2003 07:03:56
 Re: How do you engage the differential lock on an 1850? in reply to Mike D., 04-15-2003 07:52:20
We have an 1850. We used to pull it in the local farm classes a lot. Use the brakes. I wouldn't just nail it though. All you need to do is feather it a little. If you do it right you can leave a red rig sitting in your dust.
flatlander
04-19-2003 07:52:40
Well, I guess you could weld the spiders in the differential. Ought to take care of the "one wheel spinning deal". Seriously, the American made 50 series tractors never had differential locks. That may be the reason you can't find the lever to engage it.
Mike D THANKS-
04-15-2003 12:04:12
Appreciate the quick response. I'll get back to it this weekend if all goes right. Mike D.
Bob M
04-15-2003 09:06:23
Mike - We own one 1850, and I've operated several others. None of them were equipped with differential locks. Perhaps a dif lock was an option on the 1850 but I've never seen one, nor is it mentioned in the manual.
Ollie
04-15-2003 11:18:14
 Re: Re: How do you engage the differential lock on an 1850? in reply to Bob M, 04-15-2003 09:06:23
MFWA tractors were optionally equipped with lockers in front. They are explained in the service manual.
Ollie
04-15-2003 08:59:59
The technique is called "differential braking". Flip the tab that locks the two brake pedals together out of the way so that each brake has to be operated independently. Then, when a rear tire breaks loose, just nail the corresponding brake pedal. Presto! Torque is now transferred to the other tire.
