White bellhousing for 5.9 cummings
gaetan
04-14-2003 13:26:48
the white bellhousing parts number 158660 A
is that the one I need to bolt to the 5.9
cummings block and then will it bolt my two speed
over under off my 1950T. thank you
Shep VA
04-15-2003 13:47:14
 Re: white bellhousing for 5.9 cummings in reply to gaetan, 04-14-2003 13:26:48
I dont remember the part number, I will try to look for you this evening in the shop and see if that is correct.
If that is the correct White bell housing it will bolt to the SAE round pattern Cummins bellhousing that then bolts up to the 5.9 Cummins block.
There are actually two bellhousings, just like on the 1850 Perkins set up, one Cummins and one Perkins/White and they bolt togeather.
You also have to be very careful bolting the two bellhousings togeather, the Cummins SAE bellhousing is aluminum and if you pull the bolts too tight they will strip and the engine will come apart at the clutch. Not good.
I will try to check that number tonight, but it should be the only Perkins/White bellhousing there is.
