Plow Polishing
Eric Allen
04-14-2003 09:45:17
My neighbor is having a plow day this comming weekend and I have an old three bottom Oliver plow for my 77 that I would like to try out. The problem is that the plow is pretty rust. I have taken an electric wheel wire brush to it the best i can, but does anyone else have any suggestion to polish it up?
Thanks
Don-WI
04-14-2003 21:26:48
 Re: Plow Polishing in reply to Eric Allen, 04-14-2003 09:45:17
Just use it for a while, should polish up after a while just fine. Also, just use a cheap can of spray paint and paint the bottoms after you're done using it. The paint will wear off within a lap or 2 and you will have a nice shiney bottom again. Also, I have heard if you polish it with say a brick, it is best to follow the natural flow of dirt across the moldboard, as then there won't be ridges that the dirt would catch on.
Donovan from Wisconsin
Gary in IL
04-14-2003 18:02:44
go plow with it ! the sandier the soil, the better
Terry
04-14-2003 16:19:37
I have had the best luck by sandblasting the bottoms. This leaves a dull finish, which shines up very well after just a little use, and usually gives no problems with dirt sticking to the moldboard. The next best thing I have found is to use a soft brick, and rub the moldboard with that. Hope this helps, Terry.
Dkaiser
04-14-2003 19:12:26
 Re: Re: Plow Polishing in reply to Terry, 04-14-2003 16:19:37
I've sandblasted the bottoms and then sanded them smooth with a pneumatic sander and have had pretty good luck with it. The only problem is when the bottoms are pitted, then it can be a real pain.
john
04-14-2003 10:17:08
use it !!!!
mo polish
04-14-2003 18:15:56
 Re: Re: Plow Polishing in reply to john, 04-14-2003 10:17:08
Till coat when you get done is the best way to polish the bottoms.
Duane From Iowa
04-16-2003 18:31:38
 Re: Re: Re: Plow Polishing in reply to mo polish, 04-14-2003 18:15:56
DRAG THE THE PLOW THROUGH A GRAVEL PARKING LOT OR ANY ABRAVSIVE TYPE SOIL. IF YOU SANDBLAST THE BOTTOMS STAY PLENTY FAR AWAY AND SWEEP THE WAND IN THE DIRECTION THE DIRT FLOWS. MY DAD YEARS AGO,IF HE HAD A PROBLEM USED A SOFT RED BRICK IT WORKED JUST LIKE JELWERS ROUGE.
