1950 came home today
Craig
04-13-2003 14:00:42
I brought my "new" 1950 home today, it's a little strange though, It's a RC and the front axle is no heavier than my 1650, I would have thought it would be bigger, also it has the batteries in front of the dash like my 1900, I thought the xx50 series had the batteries under the floor boards???
Craig
04-14-2003 18:33:57
 Re: 1950 came home today in reply to Craig, 04-13-2003 14:00:42
Actually I did not see the battery box mount on the left side floor board, the sheet metal was off of this machine. and a home made battery box for an 8D battery was bolted to the right front frame attachement point. my 1900 has two 6 volt batteries in front of the dash, my 1650 has a battery under each floor board. I just took for granted some pin head finally decided that puting a battery/batteries puking acid rain on the electrical panel was a bad idea, guess I was wrong there..
Sam M
04-15-2003 09:31:01
 Re: Re: 1950 came home today in reply to Craig, 04-14-2003 18:33:57
My 1555 and 1855 have the batteries down low under the operator's platform . However , I always figured Oliver/White moved the batteries down low not to avoid acid on the electric panel but just so you would not have to haul the heavy battery up to what is really the highest place on the tractor . I could be giving them too much credit .
Sam M
04-14-2003 09:03:40
I think the axles on the 1650 , 1850 and 1950 are the same for the row crop tactors . At least that is the way my 1850 and a friend's 1650 are . I also have the battery in front of the dash on my 1850 . When I bought the 1850 , the previous owner had gone with one high amp 12 volt battery in front of the dash and had done away with the battery underneath the floor board .
Farmer in the Dells (WI)
04-13-2003 20:06:46
my 1850 has one under the dash and one under the left floorboard, in a battery box. What size (group) batteries do you have in your dash? Are they 2 six volts or 12 volts?
