Help. Fiat 411r diesel won't start
Al
04-09-2003 16:12:06
A friend has a Cockshut 411R (Fiat Diesel) that won't start. Possibly the same engine as in an Oliver 1250. Tractor was running fine but then started to over rev and he shut it down but then it wouldn't start. A diesel mechanic gave it a quick check over but couldn't get it to run. Does anyone have any ideas or suggestions as to what might be the problem? Thanks, Al
mick
01-05-2004 23:02:27
 Re: Help. Fiat 411r diesel won't start in reply to Al, 04-09-2003 16:12:06
my fiat is doing the same problem
did you end up getting yours to run? and how did you fix problem
m kuhns
04-09-2003 17:18:06
What for injection pump is on it? Is it a rotary pump or inline with all the fuel lines in a row? If it is an inline pump, it could have a stuck plunger.
Al
04-09-2003 17:33:47
 Re: Re: Help. Fiat 411r diesel won't start in reply to m kuhns, 04-09-2003 17:18:06
I only had a quick look at the tractor but I think it is an inline pump. They did bleed the lines and they seemed to be ok. Thanks. Al.
m kuhns
04-10-2003 14:32:15
 Re: Re: Re: Help. Fiat 411r diesel won't start in reply to Al, 04-09-2003 17:33:47
Assuming that it is an inline pump, a plunger might have started to seize in a barrel in the injection pump. You might have fuel flowing out the lines, but no high pressure, just pressure from the transfer pump. Probably what happened was that the plunger started to seize in a position where more fuel was needed. When it started to run away, you friend was lucky enough to be able to shut it down. Now the pump is stuck in a no fuel postion that spring tension can't overcome because of the plunger starting to seize. Simply put, take it off and have a fuel injection shop check it out.
