Z Split tool
seeking comments, experience
ShepFL
04-04-2003 08:02:43
third party image
All -
Getting ready to tear down my 550 for clutch replacement as planting is done. I have read about this, done much research and just about ready to begin.
Looking at the process I see I will need an xtra set of hands to seperate the rig, balance the front end after seperated and realign both halves during reassy.
Pls provide comments to my "redneckin" tool I will be building to assist me.
Look at this pic and tell me ways to improve. My plan is to build this out of 3" half-inch channel iron, weld a 5/8" grade 5 nut on bottom, thread in a 5/8" x 5" bolt for vertical adjustment. This device will be bolted to front half of the tractor (L & R sides) using existing FEL bolt holes or other factory holes of the front frame.
It is my hope that this will prevent the front end from flopping over (no overhead hoist) and once split rear will be manuvered out of the way and back into position after clutch replacement using a rolling floor jack.
G. L. Perry
04-06-2003 22:46:37
 Re: Z Split tool - seeking comments, experience in reply to ShepFL , 04-04-2003 08:02:43
I made supports for my MM Jet Star 3 by using 5" channel for uprights and a bigger 6" for a cross peice on floor. I also use a small angled flat-stock accross the uprights for a brace. I put two big casters on it. It bolted to the attachment mounting pads on each side of clutch case. On front I did similar w/out wheels and another top peice of channel which bolted to two holes at bottom of the cast-iron oil pans the have. I checked for good air pressure in all the tires and made the stands to fit setting on all four tires. When I unbolted case, just rolled rear half away on rear tires and the casters and support came with rear half of tractor. I also used two long Grade 8 bolts with heads cut-off to fit in the clutch housing holes. I tapered one end where head once was and used them as guide pins to pull tractor apart and back together. I'm not one to depend on a floor jack w/out better supports, I've seen plenty of things fall or slip off floor jacks when moving heavy items around! Once it falls, something may break and surely will be hard to pick-up again!
Pete
04-04-2003 10:51:16
Shep
I have done this split 6 or 7 times alone - I use a pair of wooden wedges placed on top of the front axle (one on each side & tapped in firmly) to keep the front from flopping around - makes it rock steady and place wheeled floor jack under the front end - use a 4 x 4 across the frame sides. a second wheeled floor jack is used under the rear - works great as long as you have a good floor. split takes about 10 minutes (not the first time) now.
When putting together watch the edges of the castings - both vertical & horizonal-to make sure that everything coming together is parallel.
good luck
Pete
