Jon, I have all of them and find them priceless. For routine maintenance, the operator's manual has all you need to know. The parts manual has detailed diagrams of all the parts with numbers so you can see at a glance exactly what part you may need. In addition to the excellent info Sam gave you, you will need to replace the hydraulic filter and gear oil filter. And when you drain the gear oil, have a BIG pan under her. I think 8 gallons is the gear oil capacity. A hint from my AGCO dealer. Never use JD or any other "manufacturer specific" type of hydraulic fluid in an Oliver. I use Farm Oyl "Ag-Master" hydraulic fluid which they recommend. Any good quality general-purpose hydraulic fluid is fine. Any good quality 75W-90 or 80W-90 gear oil is fine in the transmission/final drive. There is a level check plug for the gear oil. For the Hydraul-Shift, the terminology of automatic transmission fluid has changed recently. Use any good quality Dexron/Mercon fluid. This is what the old type "A" (GM) is now called. Just be sure to never use the old (Ford) type "F". You're very welcome,
Ollie
