66 battery box or mounting?
G. L. Perry
04-01-2003 00:29:32
Have 49-66 model. Battery appears to just sit on a "shelf" by dash. So what holds it? Don't see any ribs to set it against, no holes for bolts/holders or nothing! Is something missing on mine? Did they at least use a pad under them? If nothing was there, I'm gonna use a universal holder and run rods down thru shelf to anchor it. It had a rubber tarp strap over Batt when I got it!
CP
04-01-2003 20:05:04
 Re: 66 battery box or mounting? in reply to G. L. Perry , 04-01-2003 00:29:32
My '51 was the same way. Just sits in there. The parts book shows a wire-rod style bracket but I'm sure they rusted away and were tossed. I'm going to setup something like you mentioned and use an "off the shelf" battery bracket to mount it to the shelf. Make sure it lines up with your battery cover in the hood to have easy access later. Once the side shields are on, nobody will know the difference and you'll have the comfort in knowing it's not in there bouncing around.
