1655 gas engine troubles
Steve
03-29-2003 19:27:26
1655 gas engine cuts out/ sputters intermittently under heavy load. Plenty of fuel to the carburetor, fresh gas. Would someone please offer a few suggestions? Thanks
Ollie
03-30-2003 03:09:34
 Re: 1655 gas engine troubles in reply to Steve, 03-29-2003 19:27:26
The large screw on the carburetor is the high-speed adjustment screw and is adjusted with the tractor under load.
A bent/damaged/misadjusted governor may be at fault.
A weak ignition system may be the cause too. The plugs, plug wires, and coil are the likely culprits. Wrong point gap and/or burned points may also be at fault.
