1800 C Steering Wobbling on road
Tim
03-27-2003 12:03:21
I have a 1964 1800 C with Wide Front end.When traveling in 6th gear above 15 Mph the wheels on the front of the tractor oscillate back and forth severly.If you throttle back and slow down it will go away.The steering hydramotor has been changed from the saginaw to a late model charlyn many years ago.I have installed new spindle bushings tie rod ends (all four)set toe 1/8 in. Adding 4 slab weights on the front helped some. Any thoughts on what is left that it could be?
R.O.
03-29-2003 06:42:28
 Re: 1800 C Steering Wobbling on road in reply to Tim, 03-27-2003 12:03:21
you probably need to check your pitman shaft and center steering arm they can break the splines and cause this problem. This is what was wrong on my 1850 any way.
vaibhav shinde
02-08-2004 00:19:35
 Re: Re: 1800 C Steering Wobbling on road in reply to R.O., 03-29-2003 06:42:28
In Tractor if there is heavy wobbling in front wheel , what could be the problem , whether the following factors playing any role :
1 castor angle 2 tyre imbalance 3 stg. box play 4 front axle bush play .
RAB
03-27-2003 13:15:39
Or tyre pressure too high?
Ollie
03-27-2003 12:35:30
Wheel bearings.
