Oliver 60 gaskets
randy
04-15-1999 11:01:48
i'd like to locate a valve cover gasket, oil pan gasket, and a couple of others.
is there anyplace out there that would have stuff like that?? anyone out there restored a 60?? if so, where'd you get your gaskets??
seems to me these gaskets might be easy to make. anyone done this?? do you need anything more than a razor knife and a sheet of cork??
1941 60
04-15-1999 16:57:56
 Re: oliver 60 gaskets in reply to randy, 04-15-1999 11:01:48
I got my gasket set at Maibach Tractor, you can get most all the gaskets and seals for the 60. The governor and rear seal cover i know are no longer available but you can subtitute with cut your own or with #2 or blue goo with no problems. You might try any local AGCO dealer also as they have come out with the heritage parts line and are adding new parts for older tractors all the time.
1941 60
04-15-1999 17:05:30
 Re: Re: oliver 60 gaskets in reply to 1941 60, 04-15-1999 16:57:56
The number for Maibach's: 1 800 808 9934.
