88 engine swap
Jason
03-25-2003 19:59:40
Will a 1650 engine bolt into a 88 frame without to much work? THanks
Jerry B
03-26-2003 08:27:13
 Re: 88 engine swap in reply to Jason, 03-25-2003 19:59:40
Unless my memory fails me, I believe it is direct drop in replacement.
m kuhns
03-26-2003 13:54:07
 Re: Re: 88 engine swap in reply to Jerry B, 03-26-2003 08:27:13
The engine will fit in without any problems. We have on in our 88 diesel. I would go with the 310 with a few more cubes than the 283 out of the 1655
Jason
03-28-2003 11:12:48
 Re: Re: Re: 88 engine swap in reply to m kuhns, 03-26-2003 13:54:07
What is the diff. between the 283 and the 310? is it just the bore or is the block diff. Thanks.
m kuhns
03-28-2003 15:19:35
 Re: Re: Re: Re: 88 engine swap in reply to Jason, 03-28-2003 11:12:48
The stroke of the crank. The 283 is a 4.00 inch stroke and the 310 is a 4.38 stroke. Either or can be switched around. Basically the same block except for the Turboed 310s which had the oil cooler on the right side cast into the block.
