Why doesn't this 1650 steer?
brian williams
03-23-2003 20:31:24
I wrote earlier with no response. I found a 1650 that leaks power steering fluid almost as fast as you pour it from under the front end. Whats wrong?Is it normal for the steering wheel to spin freely with the engine off?
Thanks in advance.
Sam M
03-26-2003 06:52:29
 Re: Why doesn't this 1650 steer? in reply to brian williams, 03-23-2003 20:31:24
Sorry for the confusion I might have caused . I thought you had a 1650 ag model not an industrial model . Glad Myron KY cleared things up for you .
brian
03-26-2003 13:42:58
 Re: Re: Why doesn't this 1650 steer? in reply to Sam M, 03-26-2003 06:52:29
Mr Bender, It was my fault for not specifying. At this point though until it's torn apaart, I probably won't have more questions about the steering. Probably a bunch of others though.
Thanks
Sam M
03-25-2003 06:18:54
Underneath the cast grill and radiator , there is a steering cylinder which turns the front wheels with hydraulic fluid from the hydraulic pump . Fluid goes from the pump , through a priority vale , to a steering motor underneath the dash and then through hoses or lines to the steering cylinder . There is not a seperate steering pump or steering fluid reservoir on the 1650 . At the bottom of the steering cylinder there is a quad ring which keeps fluid from leaking out the bottom of the steering cylinder . That sounds like where your leak is coming from . I had a bad quad ring on an 1855 which leaked (even with the tractor off ) like you described just not as bad . There is also an o ring at the top of the steering cylinder that keeps fluid from coming out the top that could be bad . Also the hoses or lines going from the steering motor to the cylinder or the connections of the hoses or lines to cylinder could be leaking . Seems to me that , if these were leaking , you would get a lot of fluid coming out when you tried to turn the tractor . The only way to tell what the problem is is to remove the sheet metal , take off the grill and radiator and see what you have . A quad ring is fairly cheap but to install it you have to open the steering cylinder up and remove some of the guts to get to the quad ring at the bottom .
Brian
03-25-2003 06:34:17
 Re: Re: Why doesn't this 1650 steer? in reply to Sam M , 03-25-2003 06:18:54
Sam,
Thanks for the information. I am happy that it does not seem like something that makes the tractor not worth having. I am into it now. All I really have to do now is pay somebedy 350. to trailer it back to my area. I hate spending money that only travels one way out. Still a good price for an 80 mile trip(one way).
What I don't understand is, all the hydraulics work well besides the steering.If its one resevoir would'nt they all lose pressure when the steering bleeds so bad?
Is there more than one valve at the pump that makes this happen?
By the way this is the first tractor of any type I have worked on. Extensive knowledge on rebuilding car engines, so hopefully I can learn to understand the Oliver.
Myron KY
03-25-2003 08:13:17
 Re: Re: Re: Why doesn't this 1650 steer? in reply to Brian, 03-25-2003 06:34:17
Brian, Sam M is correct in his description of the power steering system for a Ag model 1650. Since yours is an industrial model it probably does not have a hydraulic lift system (3 point hitch).
From the I&T manual:
" On models not equipped with a hydraulic lift system, pressure for the power steering system is supplied by a belt driven gear type pump mounted at front end of engine, and a separate power steering fluid reservoir is mounted on top of the engine."
There is a filler cap on top of the hood to check and fill the power steering reservoir. Recommended fluid is Type A auto transmission fluid. Today's Dexton 3.
Except for this belt driven pump and the priority valve, everything Sam M said applies.
I would replace all the seals in the steering cylinder while I'm there. My 2�.
Hope this helps.
Myron KY
Brian
03-25-2003 18:23:42
 Re: Re: Re: Re: Why doesn't this 1650 steer? in reply to Myron KY, 03-25-2003 08:13:17
Myron Ky, You have described what this model has to a t. The tractor buffs I have as friends say that I should be filling the resevoir with hydraulic fluid.
If you read this, do you know if the backhoe should be the industrial model supplied that year. I want to order the manual if so.
By the way someone replaced the loader with a smaller case loader.
I am going to post this question, maybe you know the answer. What color should the tractor/backhoe/loader be?
Thanks,
Brian
Myron KY
03-26-2003 05:19:09
 Re: Re: Re: Re: Re: Why doesn't this 1650 steer? in reply to Brian, 03-25-2003 18:23:42
Brian, I'm glad that cleared some things up for you. As far as color I would guess Oliver Industrial Yellow. You can get color codes here Oliver Info
I have no idea about the backhoe. You can check here about the manuals, they may have more info about the backhoe. Floyd County Museum
Myron KY
Ollie
03-24-2003 07:43:16
1650s use hydraulic fluid from the pump to drive the steering box. It, the hoses, and the hydraulic fluid cooler may be leaking. The only way to tell is to get under it and look.
If the steering wheel turns easily (freewheels) with the engine off, something is wrong. Does the thing steer normally with the engine on?
Brian
03-24-2003 16:56:17
 Re: Re: Why doesn't this 1650 steer? in reply to Ollie, 03-24-2003 07:43:16
Well, I bought the machine today. The man that I bought it from says that when I load the tractor, I will need to top off the steering resevoir just to steer it on the trailer. There is a puddle approx. 5ft in diameter underneath the front axle. When I do look underneath I see what looks like a double Pittman arm that swivels in a large hub. You can tell that's where the fluid is pouring out. All other hydraulics work great. I have not tried to steer it with the engine running based on the prior owners recommendation.By the way what is a 1650 with backhoe and loader worth? Engine is supposedly a Lycoming that purrs like it was built yesterday(hour meter says 3408).
Thanks to both of you for the help.
Wrenchbender
03-24-2003 05:08:41
Does the fluid come out when you turn the wheel with the engine not running? Does it not steer wether it's running or not?
