70 oliver rear seal
ken
03-23-2003 07:11:13
I have a 70 ,3 gear can I replace the rear seal thru the clutch opening or . Will i have to pull the pan and crank thanks for any help KEN
John Holcomb
03-23-2003 19:31:22
 Re: 70 oliver rear seal in reply to ken, 03-23-2003 07:11:13
Don't even try to do it without taking the engine out. inless of course you like to swear alot.
Larry
03-23-2003 17:56:35
If you are going to replace the crank seal, for all the more work it would take, It is a two part seal and will be a lot easer just to pull the engine out, put it in an engine stand so you can what you are doing. After the sheet metal is off, three mounting bolts and a coupling bolt and it is out. The old cork can be hard to remove, nice to see what you are doing.
