880 oil pressure
Bill Rauenhorst
03-20-2003 17:24:57
What is the oil pressure for 880 oliver running wide open. I put on oil pressure gauge fron napa 0 to 100 psi and it reads 10 to 15 psi. Oil pressure light works and ever comes on when running. Is that ok. thanks Bill
B A Star
03-20-2003 20:38:14
 Re: 880 oil pressure in reply to Bill Rauenhorst, 03-20-2003 17:24:57
The Fleetline shop manual from Oliver, states that oil pressure is 10 PSI at low idle & 12 to 15 PSI at rated speed for the 880. Not much pressure, however they were all that way and ran good.
Gary in IL
03-20-2003 19:50:20
Bill;
The 'IT' manual says 'correct pressure is 14-18 pounds at high idle speed; I would assume this is where the relief valve opens
that's all I can find
G
Robert
03-20-2003 19:15:36
In my IT manual 14-18 psi at high idle is the spec. So your 880 is ok even though it looks to be low on such a high range gauge.
oliverman
03-20-2003 18:50:37
that kind of pressure is to low!! i dont have a book infront of me so i'm not sure what normal operating pressure i would think should be between 30 and 50 psi i would think!! I beleive the oil light is kind of like a warning light when the oil pressure drops below a certain point it comes on!
