Replacing Clutch in 88 -- What else to fix while in there?
Kilian
03-19-2003 18:37:29
I need to replace the clutch in my RC 88 and am wondering what else to take care of while I'm in there. I will be removing PTO, hydraulic pump/reservoir, etc.
I've thought about working on the hydrualic pump, how hard is it to replace the pump seals?
Thanks for the assistance.
Mike (WA)
03-21-2003 08:09:15
 Re: Replacing Clutch in 88 -- What else to fix while in there? in reply to Kilian, 03-19-2003 18:37:29
Also, check out the throw-out bearing very closely- would probably be a good idea to replace it.
E J
03-19-2003 19:31:10
You could put the bearing in instead of the bushing for the pilot in flywheel.Check teeth on stater ring.Also check splines on transmission input shaft & coupler.
