Time to paint the Oli
ole
03-19-2003 05:13:35
I want to paint the cab before putting it on my 1850. I would like to use a rust inhibiting primer and then either Rustoleum grasshopper or Martin Senour Oliver white paints to finish. Has anyone had good success using two different manufacturers products and had it last? What would you suggest for the rust inhibiting paint for the primer?
Myron KY
03-19-2003 12:08:38
 Re: Time to paint the Oli in reply to ole, 03-19-2003 05:13:35
I've had good results using Phosphoric Acid as a rust converter. Then prime and paint.
For more info on Phosphoric Acid, check the archives of the Paint and Bodywork forum.
HTH
Myron
