White 2-150
D13
03-18-2003 16:57:53
There's a White 2-150 coming up at auction in a couple of weeks. Am I correct that this is an updated G-1355 (Moline) with the 585? Does it have closed center hydraulics? Any experience with this beast?
m kuhns
03-19-2003 14:24:53
 Re: White 2-150 in reply to D13, 03-18-2003 16:57:53
We have one. It has been a pretty good tractor. Bad part is everything for the engine is quite expensive. I wouldn't buy the tractor if it doesn't have the external oil pump or you are planning on changing to the external pump. Otherwise you will be changing pump gears and cams when the gears wear out. We use ours to pull our 5,000 gallon tanker, 28ft disc and 13 tooth chisel plow. Everything we farm is on hills, and it does a pretty good job. THe tractor weighs 15,000lbs without any fluid in the tires and bare tractor alone.
D13
03-20-2003 03:55:12
 Re: Re: White 2-150 in reply to m kuhns, 03-19-2003 14:24:53
how can I identify if it has the external pump?
I'm not real familiar with the Molines.
IanC
03-20-2003 06:04:27
 Re: Re: Re: White 2-150 in reply to D13, 03-20-2003 03:55:12
There will be what looks like & is a gear pump just to the rear of the timing cover, with hoses going back to the cooler/filter head.
IanC
03-18-2003 19:04:40
Basically a G-1355, including closed center hydraulics. Early ones didn't have the external oil pump and had a tendency to ventilate the crankcase through the side. That's how I aquired mine after it was traded in to us "blowed up". After a new cam, crankcase, and external oil pump update completely trouble free for the last 1700 hours. It only burns about 6gal/hr pulling 6x16 onland in heavy clay.
