1855 live hyd port
Jim Meade
03-17-2003 16:56:47
The loader on my 1855 runs from the external ports. I want to plum it direct and use a joystick.
I am pretty sure I can return through the half-inch plug on the back of the casting. Where can I get live pressure, beside tapping the hyd line that runs around the back of the case?
Jim Meade
03-18-2003 06:50:33
 Re: 1855 live hyd port in reply to Jim Meade, 03-17-2003 16:56:47
I called a dealer and was told there are two options:
1. Cut the hydraulic line that wraps around the back of the case and insert a T with compression fittings.
2. Tap off the plug on the end plate of the stack valves.
Shep
03-18-2003 08:01:52
 Re: Re: 1855 live hyd port in reply to Jim Meade, 03-18-2003 06:50:33
third party image
I think mine has a T in the hydraulic line that wraps around the back. It works well and the loader has lots of power that way. I would think you could tap into the stack valves too, but I have never tried that. Good Luck.
Jim Meade
03-26-2003 04:21:53
 Re: Re: Re: 1855 live hyd port in reply to Shep, 03-18-2003 08:01:52
What cab is that?
