V8 oliver
Jason
03-17-2003 16:13:42
Does anyone have experience in putting a v8 into an oliver 88 or others? New class starting and want as much info as I can Find. Thanks.
phillip
03-22-2003 19:30:01
 Re: V8 oliver in reply to Jason, 03-17-2003 16:13:42
jason i am doing the same thing divison 7 hotrod pullers (new class)the belly pan rails on a 88 measurer 14" very narrow for v8 to fit down into for drive shaft alignment have to run jack shaft or modify rails or build front end if your local rules allow i went with newer chassie 1655 which has wider belly in bellhousing area lots of luck
