Questuons on my 1650 cockshutt gas.
Jaarno from alb
03-16-2003 19:48:59
does anybody know what brand the engine is, and do you know if the cylinders have leeves or not.
also is it posible for the head gasket to leak antifreeze.
Ollie
03-17-2003 09:04:42
 Re: Questuons on my 1650 cockshutt gas. in reply to Jaarno from alberta, 03-16-2003 19:48:59
Waukesha 265 cu. in. engine, wet sleeves. A head gasket damaged due to overheating will leak coolant.
evielboweviel
03-17-2003 04:23:15
wakesha engines wet sleeve, sounds like orings are bad on sleeves. might have bad sleeves . check on down and in archives. this has been discussed heavily in previous posts.
G. L. Perry
03-16-2003 20:00:52
Isn't the 1650 same as the MM Jet Star 3? Does it have flat top fenders on back? Square hood and grill? Cylinders in pairs? Could have a bad head gasket, or those have tubes between the cylinders for water to pass also. O-rings on them. Any chance it froze and cracked? MM engines don't have sleeves, can be bored some if you find pistons for them. Best to get an IT manual if you get into this engine. Heads and jugs come off as one. Meaning they are linked together with said tubes between them. The heads will come off seperate of cylinders though. Clear as MUD?
Canada Grant
03-17-2003 04:59:29
 Re: Re: Questuons on my 1650 cockshutt gas. in reply to G. L. Perry , 03-16-2003 20:00:52
Jet Star and 1650 totally different tractor. Cockshutt 1350 was the same.
Mike (WA)
03-17-2003 08:21:11
 Re: Re: Re: Questuons on my 1650 cockshutt gas. in reply to Canada Grant, 03-17-2003 04:59:29
Cockshutt 1350 is a MM Jet Star 3. Cockshutt 1650 is an Oliver 1650 painted in a tasteful shade of red, otherwise identical. Its a Waukesha engine, as pointed out by others.
