550 gas,normal oil pressure?
Dan
03-13-2003 21:55:58
My brother just overhauled the engine in the old 550. It only has about 18 psi at 2000rpm. Seems a little low to me, but I need another opinion. Thanks
Don
03-15-2003 04:00:34
 Re: 550 gas,normal oil pressure? in reply to Dan, 03-13-2003 21:55:58
When I frist started up my tractor I had no real oil pressure, after checking it out I found oil flow but it would not build pressure. I did not rebuild my motor it had all ready been done. but had never been started. I final found the 2 oil pasages that did not get plugged after the block had been hot tank for cleaning. It took a while to find them, if you have any questions feel free to E-mail me. I asked around but got no real answers. I final went to a old oliver dealer who was kind enough to let me look at a manul, where I could see where the plugs sould be. If you only 18 psi at 2000, you can not have any at a idle, I would not run it untill I had the problem fixed. It could just be the resristor in the oil fillter.
Don
03-14-2003 19:27:38
Not to sound simple, but is the restrictor still in the oil fillter. I purchased a 55 in pieces and had low presure at frist,restrictor was missing .I now have about 45# at 2000 rpm
Larry from MD.
03-14-2003 09:05:46
The 550 has the old style engine that squirts oil down from the top.They will run fine at that psi.I think the book says not to run them lower than 8 psi.
