Super 55/550 Seat
BigPapa
03-12-2003 07:50:21
I bought a seat that came off a 550 for my Super 55. It's the type with the rubber torsion block. It came with the bracket to mount to the hydraulic housing. My 55 is the old style with the hydraulic filter on the side. Anyway, I got it all rebuilt and painted, put it on the tractor, and it's too far forward. I have it as far back as it will go. Is there a difference between this style seat made for the Super 55 and the 550?
Super 55
03-12-2003 20:43:57
 Re: Super 55/550 Seat in reply to BigPapa, 03-12-2003 07:50:21
Take care of that seat. I just saw one go for $165.93 on Ebay, plus shipping.
Canada Grant
03-12-2003 13:27:19
AS per parts book serial number 6000 - 18134 used a different seat and bracket [with no rubber spring] than 18135 and newer including 550. But parts book says side filter used till 46000? Just checked in shed on super 55 and 550 . Early seat bolts to front of hydraulic unit later seat to back of unit. Parts book shows 3 different housings for super 55. One is replacment with updates. Don't know if early one is drilled on rear for newer seat?
BigPapa
03-12-2003 13:57:58
 Re: Re: Super 55/550 Seat in reply to Canada Grant, 03-12-2003 13:27:19
It does mount to the rear of the housing. It mounted up fine, in fact the seat that was on it was mounted in the same place, but someone had cut the factory seat off and welded some other antique tractor seat to the bracket. If I tried to space it out, it would mess up where the center link mounts.
Larry from MD.
03-12-2003 15:14:57
 Re: Re: Re: Super 55/550 Seat in reply to BigPapa, 03-12-2003 13:57:58
Mine is all the way back too.You can lift the rear of the seat to shed rain and make more room to get your leg over.
Don
03-12-2003 14:27:28
I have supper55 with orginal seat, with it all the way back, I still wish it would go back more too. seems to tilt to the front a bit too.
