Oliver 60 Engine
CWS
03-11-2003 20:39:48
Is an Oliver 60 engine the basically the same as the 66 engine? If not, can a 66 engine be easily installed in a 60? Thanks in advance.
Jerry B
03-12-2003 07:19:09
 Re: Oliver 60 Engine in reply to CWS, 03-11-2003 20:39:48
"Basicaly" the same EXECPT the 60 uses shims on the rods and mains to control brearing crush and clearance. The 66 uses precision bearings. Very few parts are interchangable.
Both engines are Waukesha built but the 66 was designed along the lines of the 77 and 88 series engines.
A 66 engine will set in a 60 and look stock except for the oil filter. You can even use the 60 bell housing and clutch.
This setup makes for a much improved 60 with power to spare and readily available parts.
