Who did white sell drill to
Tom
04-13-1999 19:18:56
When the brainchilds at white wrecked oliver who did they sell the drills to?TYE?And also was the chisel plow made by glenco?
Harrold Rhodes
04-17-1999 17:55:43
 Re: who did white sell drill to in reply to Tom, 04-13-1999 19:18:56
When White went out of business I don't think they had built drills for years. Oliver or MM. I think they were buying drills from Kirschman. The only connection to Tye is Agco now owns them.
EHW
04-15-1999 04:51:42
I cannot tell you where the drill rights went to,but I wish White made a notill drill. We just purchased a new 12 row White corn planter and never planted with anything other than Oliver or White as far back as my great grandfather. White is concidered one of the best planters built with high accuracy and low maintenance. The salesman told us that AGCO was concidering to sell off the White planter line and when the competetors ( John Deere, Case IH, and others) lined up to purchase the planter line,AGCO change there minds. As it turned out the White planter line carries a lot of weight for AGCO sales. I know in this area you dont find many used White planters for sale, compared to the gobbs of J D and Case IH around.
CN
04-18-1999 06:54:55
 Re: Re: who did white sell drill to in reply to EHW, 04-15-1999 04:51:42
There is a Case IH dealer in this area that took on the AGCO/ WHITE planter line. It shows who they think the better planter is. I know what it takes to keep a JD planter going because we recalibrate JD planter units for our seed cousomers for a little winter income. There is so many small moving parts with lots of wear points. After seeing what it takes to maintain a JD or Kinze ( samething) I wouldnt have anything but WHITE.
mm
04-17-1999 20:35:59
The White planter, since they went to the Central Air System is a fine planter. The JD planter stories vary depending on who you talk too. The most honest opinion I have heard is they suck. The vacuum pump is hydraulic driven. The accuracy varies with the viscosity of the hydraulic oil. In other words: when the oil is cold in the morning the vacuum has one value, then later when the oil has thinned out the vaccuum has another value. Your accuracy has changed. The IHC planter hasn't really changed in theory since the introduction of the cyclo. The drum has move around to the front from the back and a couple or refinements have been made. It's accuracy is lousy at the the end of the row when you are decellarating to turn around. It is handy to fill with bulk beans though.
Tom
04-17-1999 21:05:26
 Re: Re: Re: who did white sell drill to in reply to mm, 04-17-1999 20:35:59
I use a I.H now have use the old style J.D and i too have heard that the new J.D sucks for lack of a bettor word.I also heard that the white/new idea is the best on the market.And the spacing of the seeds by the I.H is poor but still ends up the same populations.
mm
04-18-1999 19:09:44
 Re: Re: Re: Re: who did white sell drill to in reply to Tom, 04-17-1999 21:05:26
Tom, Your population must be figured by the acres you get over and the seed that you go through. What you are long at the tail of one row you are short at the front of the next. An irmeasureable draw that IHC probably knew about. I imagine you plan to trade when possible. I don't think I'd be scared of a used white planter if it had been well cared for.
Tom
04-19-1999 18:04:23
 Re: Re: Re: Re: Re: who did white sell drill to in reply to mm, 04-18-1999 19:09:44
You are correct on the I.H but as this is just a hobby for me the planter does not owe me anything and works fine for what i do.I have a 1240 JD too but it is only a 4-row.Looking for a oliver close to home to buy someday, they dont bring much arnt worth much but would like one to play with anyway.
