88 engine in 77?
Ross Provine
03-10-2003 19:51:08
Does anybody know if a straight 88 engine would bolt into a 77 tub and body with little or no modification?
Thanks Ross
E J
03-10-2003 21:52:13
 Re: 88 engine in 77? in reply to Ross Provine, 03-10-2003 19:51:08
Yes,engine bolts into 77 frame.Need shorter hollow clutch tube and pto shaft,take out spacers on front gas tank support check radiator shroud for clearence may have to shim up some.It can be done.Have did one also 880 motor in 770 and a 283 in 77.
Dano
03-11-2003 16:55:16
 Re: Re: 88 engine in 77? in reply to E J, 03-10-2003 21:52:13
E.J.,I've heard of putting a 283 into the 77,what problems did you run into?
E J
03-11-2003 21:30:20
 Re: Re: Re: 88 engine in 77? in reply to Dano, 03-11-2003 16:55:16
Cooling not enough radiator if you pulled to hard for a while.More rows of tubes may help.
Dano
03-13-2003 18:02:19
 Re: Re: Re: Re: 88 engine in 77? in reply to E J, 03-11-2003 21:30:20
Did it bolt right up,which clutch,flywheel,etc.and what about motor mount position?
