Oliver 550 diesel, lubercation ?
Harvey Taylor
03-08-2003 17:32:08
I just bought a 550 oliver diesel tractor, does anyone have a picture showing lubercation points, oil type and weight, is the transmission & hydrolic system two seperate units? if so what does the transmission take, 85/90 weight? I noticed there is a fill cap & dip stick under the seat, also there is a twist off cap on the transmission, below the steering wheel. Any help would sure be apprecated, thanks, Harvey
jake
03-08-2003 21:27:27
 Re: oliver 550 diesel, lubercation ? in reply to Harvey Taylor, 03-08-2003 17:32:08
The systems are seperate, the front plug is for the trans and rear end. The level is determined by removal of the pipe plug on the righ side of the PTO, it takes 5 gallons of 85-90 wt gear lub. The hydraulic is the plug with the dip stick and takes 9 qts of hydraulic oil. If the hyd oil needs to be replaced it can be pumped dry by removing the plug on rt frt of the top cover, screw in a small pipe nipple with a hose and start engine till all fluid is out.
klf
03-08-2003 18:34:38
I'll have to look up the rest, but you can't go wrong using 15W-40 in the crankcase.
