Wheel weights vs fluid
ole
03-06-2003 21:27:08
should I be using wheel weights for traction vs fluid, both, and does the added weight damage the tires without fluid in them?
Ollie
03-08-2003 03:16:37
 Re: wheel weights vs fluid in reply to ole, 03-06-2003 21:27:08
Don't listen to those who claim CaCl causes rim rust. It's not possible. The water/CaCl mixture goes into the tube and cannot possibly contact the rim. As long as the CaCl is installed properly, it's trouble-free. My 18.4x34s have had CaCl in them for more years than I can remember with no problems.
Scott Green
03-08-2003 04:43:26
 Re: Re: wheel weights vs fluid in reply to Ollie, 03-08-2003 03:16:37
I agree Ollie. The only way calcium will rust rims , is a leak in the tube/valve stem. No leaks , No rust.
Dave_Id
03-09-2003 07:58:19
 Re: Re: Re: wheel weights vs fluid in reply to Scott Green, 03-08-2003 04:43:26
...and that is where the main problem lies, the valves. There always seems to be a drop or two pop out when you hit rough ground, I have replaced the valves, replaced the whole tubes, and still have that small problem. I'm getting rid of the Calcium Chl. in my Massey.. unfortuneately, I'm sure wheel weights won't be cheap, but I should have put the couple of hundred bucks I spent to have the tire guy come out to the farm into the wheelweights.
Ollie
03-09-2003 10:19:52
 Re: Re: Re: Re: wheel weights vs fluid in reply to Dave_Id, 03-09-2003 07:58:19
Easy fix.
First, the tires must never be more than 3/4 full of water/CaCl. If they are, not only can you pop fluid out the valve, you can get real lucky and split a tire. Water does not compress.
Second, run only enough air pressure to get the tires up, no more. For example, I run my 18.4x34s at 11 psi.
Third, any auto parts store will sell you chrome plated (not important) brass valve stem caps with no hole. They also have a rubber seal in them. Even without a valve, they will seal air tight. With a valve, my air pressure hasn't changed at all in 5 years. Yes, I know, I should check them more often but there doesn't seem to be a need to do so!
dean
03-07-2003 22:52:30
use fluid in my pulling tractor and feel it is better than wheel weights as mentiond in earlier posts..more compaction of dirt directly under tire and tread is spread out more evenly with less deflection..downfalls are limitation of classes you pull in..not easy to go up or down in weight classes..if dont want to deal with rust then use methanol alchol mixture and eliminate that problem..specific gravity weight is less per gallon than that of calcium but dont have to worry about rusting problems,,,also ej i think it was, mentioned fluid causing power loss..would like his explanation on why this is so? weight is weight unless you are turning so much tire speed that centrifugal force becomes a factor..guess im just dense
RAB
03-08-2003 12:50:16
 Re: Re: wheel weights vs fluid in reply to dean, 03-07-2003 22:52:30
IF the wheels were the same weight AND the weight is distributed differently - one with mass at centre(wheel weights) and one with mass at rim (liquid ballast), then the one with the mass at the rim WOULD absorb much more energy acting as a flywheel. Therefore it would rob power as it speeded up and give it back as it slowed down, possibly when you did not want it during a pull.
BUT as the liquid isn't solid and does not travel at the same speed as the wheel it WON'T absorb energy like a solid flywheel - and won't give it all back when slowing down.
If it does rob power, where will it go? Answer - heat! If your ballast heats up during the run you can calculate the energy absorbed using basic physics - mass, temperature rise and specific heat of the ballast. You will need to compare this heat gain with tyres filled with air, as well to find the difference the liquid makes!!
I, personally, would think that power losses are actually difficult to assess, buried amongst other factors such as slower flexing of tyre wall due to higher fluid viscosity (liquid vs air) etc.
Regards, RAB
Jeff
03-08-2003 10:40:42
YOu say you would rather use fluid instead of weights when pulling. I did that last year to get my 88 up to the 5500 class after putting pressed steel wheels on it. Maybe it was just the tracks but I noticed that on an an extremly hard track my back tires would kinda vibrate then break loose and spin. This happened after I changed the wheels and tires but never before. I had the cast centers and 13.6's on it first then went to the pressed steel and 15.5's. Have you ever had that problem? This is also in Farm Stock class pulling in 1st gear. Second doesn't seem to do it.
I was told on here at one time that the reason was that the fluid will get a vibration in it and cavitate? I was considering going to wheel weights to stop that problem if that is what it is. Any suggestions?
klf
03-08-2003 19:06:41
 Re: Re: Re: wheel weights vs fluid in reply to Jeff, 03-08-2003 10:40:42
A wider tire does not give you better traction, unless you increase the weight. Otherwise, you get a flotation effect. A narrower tire will bite in a lot better.
Geoffrey
03-07-2003 20:25:48
I'm with E J. The fluid with calcium will eat the rims. I have not had an Oliver with it, but my SMTA Farmall did. After I got it I took the fluid out, washed the rims, cleaned the scale off, sand blasted them and painted them with good primer and paint. Well a year later they were rusting again! No it isn't just the color of the tractor either. I now use four wheel weights per side and am very satisfied with that.
E J
03-07-2003 18:21:51
Fluid robs tractors power plus destroys the rims with rust.If you need ballast use wheel wt's.
jeff
03-08-2003 10:34:57
 Re: Re: wheel weights vs fluid in reply to E J, 03-07-2003 18:21:51
Just curious how the fluid will rob power in relation to wheel weights? If you have say 600 lbs of fluid per side or 600 lbs of weights what will make the fluid rob power aand not the weights? Seems that a ton of bricks weighs the same as a ton of feathers.
opp
03-08-2003 19:12:39
 Re: Re: Re: wheel weights vs fluid in reply to jeff, 03-08-2003 10:34:57
Take a glass of water and rotate it. The water will soon get up to the same speed of the glass. The water is moving with the glass. When you stop rotating the glass, the water will continue to rotate. If you had a glass of wax, you need the energy to get the wax and glass to rotate at the same time. When you stop, you need the energy to stop them both.
Jef
03-09-2003 06:48:56
 Re: Re: Re: Re: wheel weights vs fluid in reply to opp, 03-08-2003 19:12:39
BY that it would seem that fluid would be better even if you were running faster becaseu since the energy in the water is there already when you are moving once you slow down the momentum of the water moving faster would still try to push you faster.
Dean Barker
03-07-2003 21:44:15
I bought a 4320 that had fluid in the rear tires. The rims were so rusty, the chunks of rust would break loose and puncture the tube. After the second flat tire, I ended up buying some rust free rims and mounted the tires tubeless.
Dean Barker
03-07-2003 21:43:48
John Holcomb
03-07-2003 12:23:20
I have had excellent luck in dead weight tractor pulls with fluid. I feel it gives me better bite because my tires dont squirm as much,because the fluid does not compress like the air will at low pressure.
Ollie
03-07-2003 08:10:06
I push snow with mine so either fluid filled rears or chains are required. I use fluid and am very happy with it.
Greg Davis
03-07-2003 06:01:41
There should be no damage to the tires. Although I have some fluid in mine, I believe that not having fluid in them will allow the tire to flex and do what it needs to do to have maximim traction. When I get a chance I'm going to get the rest of the fluid out of mine. Just my opinion.
