3 point
HD1200
03-04-2003 18:31:26
I have a 1250 and when the 3 point is raised even with something as relatively light as a scraper blade attached it has a steady bounce. Like the arms are starting to fall and then jerk back up. Also when you shut tractor off 3 point falls. Is it just plain wore out?
Geoffrey
03-04-2003 20:06:47
 Re: 3 point in reply to HD1200, 03-04-2003 18:31:26
I'm sure not an expert or anything. I know just about hydraulics enough to be dangerous. It sounds to me like you migh have a hyd. valve leaking the fluid back as soon as the pump stops.
