Chain Couplers
VADAVE
03-03-2003 17:00:46
Thinking about the discussion on coupler chains breaking and realized that I had not heard anyone talk about their 2150 or 2255 chains breaking. I have not looked at one of these--Do they use chains or some other kind of coupling?
Lee W
03-03-2003 20:52:02
 Re: Chain Couplers in reply to VADAVE, 03-03-2003 17:00:46
They don't use the chain, it is a trunion mount.
VADAVE
03-04-2003 18:21:00
 Re: Re: Chain Couplers in reply to Lee W, 03-03-2003 20:52:02
I read in one of the posts that later 1855/1955s had 2-105 rear ends, is that correct? If so could the trunion coupler be adapted to the 1855/1955?
m kuhns
03-05-2003 19:03:54
 Re: Re: Re: Chain Couplers in reply to VADAVE, 03-04-2003 18:21:00
I would think it would be possible. You would however have to change the overdrive clutch piston carrier on the over/under to the one with the trunnion mount. The bearing holder for the input shaft of the trans. would have be change also. You would have to get a different gear to put on the over/under as well as a coupler. Might be money well spent. THe only problem that I can see, is that there might not be enough clearance between the frame and engine/torque to get things parallel to slide them together.
