70 oliver engine parts
Daniel Moore
03-02-2003 16:50:17
Does any one know where i could get an engine re build kit? Are they even avalible? Right off the top i need, pistons and sleeves, rings, lifters, bearings, oil pump, 1 push rod, intake and exhaust manifolds, and all the gaskets. Can anyone help me?
jim
03-12-2003 20:22:26
 Re: 70 oliver engine parts in reply to Daniel Moore, 03-02-2003 16:50:17
I have pistons, sleeves, lifters, crank, head and valves (ground), oil pump and other odds and ends that came out of a 70. If interested, contact me.
Dan
03-03-2003 23:11:26
I have sleeves and can get pistons for a 70,the sleeve are 3 5/16 I am going bigger.
Jerry B
03-03-2003 07:54:40
I have a set of 3.250" aluminum pistons, wrist pins, rings and sleeves. Brand new, in the box.
Contact me if interested.
John Holcomb
03-02-2003 19:41:08
As I have said a number of times a 70 is expensive to rebuild. I have all the parts you cant find at the auto parts store. your best bet is to find a running tractor a $1000 for a tractor is cheaper than a rebuild. I have a running 3 gear with a good manifold for $750 you would be money ahead it buy it. Or you can build your own for 1500 to 2000.
