OC-3 speed reducer
Glen
03-01-2003 19:50:02
Looking for a way to low gear this little machine to make it more useful for Dozing.I know about the model A ford conversion set up.More interested in keeping the machine very close to original. Thinking in the line of placing a gear reducer in place of the coupler yoke(between the clutch and transmission.Anyone with information on what I can use and where to buy.Please include phone#'s) Thanks very much fellas, Glen,email SHELLY.GLEN@att,net
Mark from Genoa
03-03-2003 20:48:54
 Re: OC-3 speed reducer in reply to Glen, 03-01-2003 19:50:02
I have seen a setup with a chain drive arrangement. I would question the use of a chain drive in this application. Low tooth counts on chain sprocket result in excess vibration and I would not recommend using chain drives at these line speeds. I would look at something like a Gates GT or Eagle Pd toothed drive belt. I have used these in winch designs and they transmit a alot of power at much higher RPMs, although the Gates design in somewhat noisier. I would also worry about the overhung radial load applied to the shafts since the original setup using U-joint which do not place a large overhung load on the output and input shafts. It might be wise to looking at designing a jackshaft with bearing supports to eliminate loading the output and input shaft radially. Commercial gearboxes are available however they are hard to find in low reductions. I would think you would want to limit the initial reduction to 1.5:1 ir 2:1 at most.
Dave Grubb
03-05-2003 17:51:51
 Re: Re: OC-3 speed reducer in reply to Mark from Genoa, 03-03-2003 20:48:54
If you read the thread by Mike Anderson you will find that is exactly the problem he had---and for the reason you just stated. I had not thought of a toothed belt, but it sounds like a better way to go. I know Mike has some thoughts about redoing his, I'm not sure if he has given that approach any thought.
Dave Grubb
03-03-2003 18:48:49
Go to>Link
Look>Link for Mike Anderson or do a search. He just did one and posted pictures and all. Really a wonderful job, very neat--but it dind't work out for him (and he tells why). You can get all the detials if you go through the threads and look at the pictures as well.
Glen
03-02-2003 11:17:14
Hey RAB, Need help finding that article .Searched all over HPOCA. Thanks Friend, Glen
RAB
03-03-2003 15:08:25
 Re: Re: OC-3 speed reducer in reply to Glen, 03-02-2003 11:17:14
Sorry!!!
Try Cletrac.org under the OC/HG forum. I remembered it was one of those I cannot read properly - on a blue background - unless I highlight the text!!
Regards, RAB
Mike (WA)
03-03-2003 08:34:43
Glen- The HPOCA article is the Model A conversion- shows how to make a bell housing out of a piece of round pipe to adapt the two. I'm at work so can't tell you which issue its in.
RAB
03-02-2003 06:02:27
I believe there is a write up of a conversion, on the HPOCA board, on this very subject. The guy may well have put on information as to how it worked out, but I thought it may have problems with axial/radial loads. Assume you are considering this for an OC, not a Cletrac HG as the early ones may not have enough support on the final drive shafts to allow too much slow speed torque increase without risk of mechanical overload.
Regards, RAB
