88 Sleeve in a 77 block-again
Keddano
02-27-2003 15:48:01
Getting closer to tearing down the 77,looking for input again on anyone that has bore the block on a 77 and put 88 sleeves into it. Thanks again,Dan
A.P.
03-01-2003 04:02:11
 Re: 88 Sleeve in a 77 block-again in reply to Keddano, 02-27-2003 15:48:01
Dan it is certainly possible tto machine the block and drop in a 3 3/8" bore pistons and sleeves. I haven't done myself but for the work involved I would contact Brd at Maibach Equipment in Creston Ohio. He has a 4 1/16" bore piston and sleeve set available. You will need to machine the block for the larger sleeves and use a different set of rods or hav the ends of you rods bushed. I don't have Maibach's phone number handy but I will try and find it if you are interested.
Take care,
A.P.
Dan
03-02-2003 09:14:58
 Re: Re: 88 Sleeve in a 77 block-again in reply to A.P., 03-01-2003 04:02:11
Got their ph#,Talked to them a while back.The cost for their kit will brake the farm.I read that the 88 cast sleeves don't hold up being bore to 4" very well.May look at a custom aftermarket sleeves.Thanks
