Open / closed hydraulics
Reaver
02-23-2003 23:07:16
Which Olivers have open center and which have closed center hydraulics?
What do you recommend...for a loader tractor?
Thanks Reaver
Shep
02-24-2003 10:21:38
 Re: open / closed hydraulics in reply to Reaver, 02-23-2003 23:07:16
OK I will take a stab at this one, and if I get one wrong someone correct me.
All oliver tractors are open center hydraulic systems EXCEPT:
1755
1855
1955
2255
2055
2155
G-1355
1870
2270
All of these are closed center hydraulic system tractors and maybe some of the small feit engine tractors, Im not sure.
Either system will work with a loader, I have run both, I think the bigger issue is making sure you put an external loader valve on the tractor and hooking to the power beyond or directly to the pump to get good pressure to the loader.
IanC
02-24-2003 12:36:14
 Re: Re: open / closed hydraulics in reply to Shep, 02-24-2003 10:21:38
All Fiat/Olivers were open center systems. We (I'm a New Holland parts man) can get most Fiat parts right through New Holland. It's the Iseki's that I'm not sure about. P.S. did you ever find Krone?
