Super 77 paint and steering question
eric
02-18-2003 18:06:13
i have seen some super 77s with green wheels and no red. did oliver do this or is this just a repaint? did super 77s ever come with the clover white? olivers are my favorites but i am not fond of the green red yellow combo.
next question, inside the steering box under the radiator on my super 77; down at the bottom towards the front there is a screw. mine was really loose. what is this for? it screws strait towards the ground. i cant see what it holds together. also my steering box was full of grease, i cleaned it out the best i could and put in 90 wt. it leaks bad (like what was i thinking the grease was there for anyway? duh!) it leaks out the steering shaft hole. any simple fixes other than going with grease again? as always thanks for your time and help. eric
Larry from MD.
02-19-2003 06:38:36
 Re: super 77 paint and steering question in reply to eric, 02-18-2003 18:06:13
The olivers made in 54 and 55 had green wheels and no red on them.In 56 they went back to the red wheels.When the 770's came out they went to white and green.Yes leave the grease in there.The bolt you talk about is the ajuster for the gear mesh.It both holds the gear down and up,so to remove the cap you have to screw this in through the cap as you lift the cap off.Jack up the front end and tighen it up untill you feel it drag when you turn the wheel.Then back off a little.
