49 row crop
Jim K
02-16-2003 05:21:04
Can someone tell me what a 49 row crop would be worth. 6 cyl needs block welded drivetrain is good
needs tires, sheet metal good, missing side panels
I think that it's a super 77 not sure. owned by a little old lady (widowed)would like to give her a fair price for it.
Thanks Jim K
Mark
02-17-2003 15:26:38
 Re: 49 row crop in reply to Jim K, 02-16-2003 05:21:04
I wouldn't give her more than $500 for sure, and would shoot for less. You will put $2000 to $3000 into that tractor (at least) to get it to a restored condition, and it will not be worth that when you are done. The cracked block is tough to comment on without seeing it, but will not hold the value of an undamaged block, regardless. I would consider it a parts tractor and offer $300 or less. You should be able to recover that by parting it out should you decide against fixing it. If you can get it welded and running you still need tires & side panels, which are not cheap! Take this for what it is worth & Have Fun!
CP
02-16-2003 21:50:28
If it's truly a '49, then it can only be a 77. Supers weren't built until '54. Sounds like a lot of work to get her going if you intend to rebuild and get running again. Fair price depends on what area of the country you're from also.
jocco
02-16-2003 13:06:51
depends on your area and it sounds like a parts or serious restore i would estimate 3-500 but cracked plock is a problem* also 70 or 77 is exspensive to restore
