Oliver 77 ?
Rick
02-14-2003 08:22:50
How do I tell if it's a 77rc or a Super77rc ??
Larry
02-15-2003 08:28:55
 Re: Oliver 77 ? in reply to Rick, 02-14-2003 08:22:50
As far as I know, the "super" models didn't have side curtins. There was some problems with overheating in hot weather with the fleetline series. The H>P> was upped for the super series and the side curtins were eliminated. The hood is styled.
dean
02-16-2003 10:13:02
 Re: Re: Oliver 77 ? in reply to Larry, 02-15-2003 08:28:55
the supers did have side curtains just not full cover with louvers..they were cutout to allow for more air movement..supers also had a flat mounting area at the nose of the tractor cast into the frame..non supers were rounded..makes it easy to spot from a distance
Farmall Daddy
02-15-2003 07:54:28
Look for a serial number near the right brake housing. My 88's serial pad says that it is an 88 and that it is a row crop. Also if it is original, and hasn't had any motor work done to it that you know of, check it on a dyno. Good Luck!!!
Gary
02-17-2003 09:17:27
 Re: Re: Oliver 77 ? in reply to Farmall Daddy, 02-15-2003 07:54:28
The serial # plate for later 77s and Supers are on the left lower side of the dash area.
evielboweviel
02-14-2003 12:37:30
s77 has holes for pipe frames and mounting pads for newer equip
77rc has pipe frame holes only no mounting pads
other differences also
