Oliver 1265 PTO
Matt
02-14-2003 08:16:30
My 1972 Oliver 1265 deisel seems to have an issue with the PTO engagement. Even with the clutch pedal (2 stage clutch) fully depressed, when I engage the PTO lever it doesn't want to engage. I need to force it into gear in a quick motion. It will engage as long as engine RPM's are low but even then it will "grind" abit before engageing. I've tried depressing the clutch and waiting for a minute thinking that the gears just needed to slow down enough to engage but that didn't seem to help. Do you know if a simple clutch adjustment would work? Thanks in advance.
